Home > Technical > Locked access height...
Korenai
Switzerland 2007 Range Rover Sport TDV6 HSE Java Black
Ok, so when I select the normal access height, around 20 km/h the car automatically lift itself up. But what about if I lock it? Will the car lift up at some point?
Probably it's in the manual, but it just came up in my mind and can't check it now... Embarassed
Post #193193 Mon Oct 27 2008 10:44am
The car always raises itself from access height once you move off, even if locked... Very Happy
Post #193195 Mon Oct 27 2008 10:45am
Korenai
Ah, so what's the point in locking it?
Post #193196 Mon Oct 27 2008 10:46am
Jonny Fresh
Exactly what I thought when I discovered this! Anyone know?
Post #193202 Mon Oct 27 2008 10:59am
I think the "raise" speeds are different aren't they?
If you lock it for access to that underground car park that you can't fit in it allows you to drive at car park speeds to your place. However, if you keep it in access height because you're a shortarse and need it to be able to get in then it raises itself earlier....
Someone will doubtless prove me wrong Embarassed
Post #193204 Mon Oct 27 2008 11:03am
Korenai
Yeah, that was my idea... Different raising speed... I'm sure about the first one, when the car is in non-locked access, but I don't know the locked one.
Post #193208 Mon Oct 27 2008 11:08am
Jimmy_75000
The locked one allows you to drive up to 10 mph I believe in access mode. And you get an extra warning before the car raise to driving mode. Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #193216 Mon Oct 27 2008 11:21am
Lookers Park Royal
Example:
You drive into a multi-storey car park which is only marginly higher than your RRS. If you lower the car and drive gingerly to your space then you will be fine as long as you drive below the activation speed. The problem lies when you come back to the car, put your shopping in the boot and pull out of your space.................
Crunch!!
In that situation if you lock it in access mode then it will stay in access mode until you unlock it or exceed the target speed.
I say target speed as I'm not sure if it is different from market to market. Therefore check your handbook.
Just an example of why it is very very useful!
James Thumbs Up
Post #193224 Mon Oct 27 2008 11:54am
ViewWise
on mine if i dont lock it, it comes up at 10mph. If i lock it it beeps to remind me at 25mph and comes up if i exceed this.
Post #193228 Mon Oct 27 2008 12:45pm
Korenai
Ok, got it, thanks. Thumbs Up
Post #193229 Mon Oct 27 2008 12:46pm
Bobby
You are in "CRAWL" mode when you 'lock' the vehicle in Access height.
1. The suspension will automatically rise from Access height when the vehicle speed exceeds 10 km/h (6 mph), regardless.
2. "CRAWL" mode allows you to drive the vehicle at low speeds at Access height (as in low car parks). However, on-road height will be selected automatically if the vehicle speed exceeds 40 km/h (24 mph).
Hope the above explains the difference between Access and Crawl heights.
...and there is a point in locking it!! Wink
PS. Locking in Access mode (CRAWL mode) is not for the purpose of holding it in Access mode whilst parked. Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #193316 Tue Oct 28 2008 12:53am
Nice one Bobby! Thumbs Up
Post #193361 Tue Oct 28 2008 12:06pm
