![]() | Home > General > WARNING!!! Windscreen replacement |
I have recently been having a problem with water in the footwell on the passenger side of the RRS. The known TSB's didn't fix the problem but Guava in Guildford sorted the problem! |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Good bit of advice VA |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
Isn't your water problem due to the proximity of the Thames? |
Get back to work Jimmy! |
OK OK .... ![]() ![]() ![]() Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Excellent advice VA |
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 ![]() ![]() |
Hmmm...about two weeks too late! Despite letting them know about replacement clips (as per VA's previous advice) on the trim they broke most of them and used super glue to fix rather than spend a few dollars to replace. They have now replaced them but it leaves little confidence as to what other damage has occurred. |
Nice one VA! RRS TDV6 Gone but still around
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
VA
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Chris, They have a habit of flying off at speed (hopefully not along the side of your paintwork) if not refitted properly, therefore you should certainly get it checked. Ideally the clips should be replaced as it is difficult to remove the trim without breaking at least one. James ![]() |
Thanks James I'll pop it back in to them in the morning to have it refitted.
MX Member Since: 06 Mar 2008 Location: Been to Moscow, beat the blues....what next? Posts: 152 ![]() ![]() ![]() |
I had exactly the same problem when my D3 screen was replaced.
IIRC, the A-pillar trim flew off MDP's S/C ages ago.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I have posted on here before about screen replacements (I had a few ![]() ![]() I had them back to replace and they fitted a new screen also just in case - the water appeared to be getting into the pillar through the trim holes and down onto the floor somehow through the body work. I think Bobby posted a bulletin about a mod to the trim fixings to also reduce water ingress risk. THe other thing to watch for is that they centralise the screen - if not you can see into the trim from the outside on one side and not the other - the airbag and cables become visible.... |
