![]() | Home > Technical > Creaky and squeaky noise from front suspension!!! |
| dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450
It is not the known knocking... It is strange creaky noise. It started today. The noise goes from front shock-absorbers, or some others parts - I dont know. It is doing that noise only when i go slow and on rugger road. I also tried to raise the car to off-road mode - it makes that noise! But what worse... the raising of the car is unbeliavably slow! The raising usually takes 5 seconds, but now it takes 1 minute...
Bushes...?? What it is? I cant find it in dictionary. RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
Rubber bushes (or gromits) that are attached and sit at the ends of the anti roll bars. |
Thanks!
NP. Fine to drive, just irritating |
And Is it normal that it raising to off-road mode 1 minute?? RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
That sounds like a different issue and most certainly points to a compressor fault. Best to get that checked at the same time, unless of course you are planning to off road reguarly or sooner, in which case, get her in before venturing in to the wilderness......you never know if its going to fail. 1 minute is far too long and it should take no longer than 5-10 secs. 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
I dont think it is compressor, because the rear suspension is in 5 seconds up. But the front suspension reach the offroad mode after minute...
See what the experts say...let us know dadanek. 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
| 2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382
You may have a small slow leak in the front air suspension causing the slow raising of the front. |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
I think its these bushes...
4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Bobby it's usually an insert of some sort of hardened plastic (in other applications they are made of brass or bronze even) that get inserted into a suspension point or place where wear can occur with two metal surfaces rubber on each other - the bush is "sacrificial" and less expensive/critical a part to replace than the main components.
Bobby Have you got more diagrams of the RRS underpinnings? I am particuarly requiring the ARC unit and front suspension as an overview and the individual components. 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
Tim, many thanks for the educational info on 'bushes'. I posted the above diagram because Will suggested that the problem could be 'bush' related and poor dadanek was not sure what 'bushes' meant! Will must have mentioned 'bushes' because there was a TSB issued way back in 2006. This concerned complaints of creak/squeak noises from the front of the vehicle. Apparently LR suggested replacing the stabilizer bushes with new ones that are impregnated with Teflon, which were just available then! However, this only concerned the RRS Supercharged! The inserts you mentioned are related to a TSB issued August 2008. This concerns knocks from the front or rear suspension. It seems the stabilizer bushes get compressed, leave a gap and thus causing wear. It is recommended to insert 'strabilizer bar packers' between the bushes and the chassis. But this is for vehicles without ACE! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
