![]() | Home > Off Topic > IT geeks - What is WinRAR? |
It's an artefact of the install routine that leaves these files behind and they are normally cleared away upon next reboot.
That IP address is known as the loopback address and basically means "myself".... I'd expect that it should be updating itself from a source on the internet, but as I say I don't have the software so it maybe that it's proxying through something else? Is there a firewall installed on the PC? ![]() 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
S, I found on the kaspersky website that there are a lot of viruses which use the HOSTS file to prevent the user from connecting to the anti-virus company site.
When you say they're inaccessible, what do you mean? These files don't have extensions (like .txt or .doc for example), but you can open them in Notepad and edit them from there |
Yeah, they don't have extensions.
F |
monkey9952 Member Since: 09 May 2007 Location: In A mess Posts: 163 ![]() ![]() ![]() |
I would Delete all entries associated with Spybot , save the file then reboot. Hopefully that will sort it. |
Done all that! |
Might be the registry , there is a reg file you can download install and it cleans all spybot registry entries ... might help ?
Do the activation details work across versions?
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 ![]() ![]() |
Go on chuck it in the pool - then buy a mac |
It is currently sat next to the pool awaiting a good dousing! |
Mate, you can fly me out to fix it for you if you like |
Was just about to book your flight....
