![]() | Home > General > MWAY BREAKDOWN |
| bt11 Member Since: 02 Mar 2008 Location: North west Posts: 95
So I’m travelling along at a steady 130mph.... |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554
Any idea what VIN range was affected by this? |
| TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927
Hang on, lets not press the panic button just yet. This is a one off incident as far as we know.
| Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980
1 car in how many.......chill winston...... Speed Limits! not where I live!
One in about 400,000 so far. . . Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
From what i can remember... the senior engineer said that the older filter has 2 particle filter sets within the unit itself.. the new one has 5 so far more filtration.. This he said is due to the amont of bio fuel being mixed with everyday diesel now
Range Rover Sport TDV8 OVERFINCH ECU remap/tuned, 22" Satin Black Tigers, Black/Black, sideskirts, tints, clear ind, 09 upgrades +++ Plus others...... |
Bio fuel being mixed with diesel |
| Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905
This has been posted before Steve.
When I was in the Army part of the job that I did was the testing of fuel, ground, aviation and naval. Basically I had a mobile lab and would go to where ever to test the quality and grade. As you can imagine, when overseas the 3 services purchase the fuel localy, in places like Bosnia, Kosovo, etc etc, the quality is not quite what you would expect from your local supermarket. What I'm getting at and you may have seen yourself from time to time, is that forecourt testing of fuel is done on a regular basis, not just to calibrate the pumps. The major players would never risk the wrath of HM inspector of.......and so on, not to mention the bad press and all that. Speed Limits! not where I live!
I remember reading in one of the motoring mags that after July 2008 all diesel in the UK was going to be routinely mixed with Biodiesel, but the percentage would be very small - <5%. I think the percent might even be higher sur le Continent. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Yes your right Tim, many countries have wanted to blend 5%, this is the maximum figure that they believe they can use without needing to modify the manufactures engines. The reason for blending, well its like watering it down basically, all down to money and profit. The biggest problem though is the manufactures are having none of it, by saying you will void your warrenty by running the vehicle on anything but the reconmended fuel. Speed Limits! not where I live!
| McBunny Member Since: 18 Sep 2008 Location: South Posts: 679
Hi @all, very short to all the guys who didn't read my entry post: I'm new and want to buy a RRS soon. I have been reading here for a little while now (great forum btw BUT since I have been working as a consultant for a company that was directly affected to Biodiesel and the laws among it, I know a little bit about that so I can just answer this little point: Whithin the whole EU this should be 5% by now (at least that's what the EU said some years ago) but I'm not quite sure if this is still actual and if each country really sticks to it already. The Biodiesel-percentage in Germany is exactly 5% due to a German law (in fact it must be a minimum of 5% but since it must be German Biodiesel due to some perfect lobby work and since German Biodiesel meanwhile is more expensive in production than mineral diesel including tax it will be exactly those 5%). It was said to be raised up to 8% and then 10% but German car manufacturers said this would be harm some of the engines and so the percentage is still 5%. Two words to Biodiesel and modern engines: The main problem with Biodiesel is that it is sometimes (especially in summer) made from cheap raw materials and with very little additives since they are veeery expensive and then it can become marshy when it is not moved for some time (or when it is to cold or it becomes marshy without any special reason, it just does) which can of course seriously damage your engine. This is the main problem with Biodiesel (and it is a huge problem, I saw masses of damaged engines due to cheap Biodiesel). All the nonsense about it being to aggressive or to destroy seals or something similar are just propaganda of some well-paid lobbyists. In winter time however the Biodiesel is a lot better (because the cheap one would just jell in cold temperatures) and therefore should not harm your engine. (I know people who just bought the winter stuff and used this over the whole year, they did not have a single fault on their engines over more than a hundred thousand miles run on pure Biodiesel although they drive modern Audis and Beamers which due to the car makers can't be run on Biodiesel! But if you don't have your own filling station this information won't help you anything, sorry. Just my 5 cents, in fact very long 5 cents. But it's the first time I know something so of course I wanted to tell you... |
McBunny, first welcome to the forums.
Hi Tim,
| All times are GMT |
