![]() | Home > Technical > Extended Mode Failing? |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
Has anyone encountered the car going into extended mode but the rear suspension lowering? I had this when I was off road a few weeks ago and the consequence is some scraping/damage to the back of the underside of the car asround the rear axle. The front of the car which raised is perfectly okay.
Thanks Tim, alas i don't have the Sat Nav option in my car! |
Not sure this counts as a warranty fix but the stealer has agreed to replace the damaged plastic spare wheel wind deflectors and bash out the slight dent in the fuel tank protector caused by this fault.
