![]() | Home > General > integrated bluetooth after the fact |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
hi guys,
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Go with an aftermarket product like Parrot, 10 times better than the LR one. '08 RRS TDV8
thanks, does that give you the option to dial via the radio ? or does the LR kit even do that ? |
No the Parrot is a separate module, you select the contacts on it. With the LR kit you can dial via the radio, kind of, you can select the first letter of the contact on the keypad but then you have to scroll through the contacts with the selection wheel(or the switches on the steering wheel). What you do not get with the LR kit, at least with the Nokia 95 and for what i can see most of the headsets, are multiple numbers per contact, call history(dialled, received). '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
No, with the LR Kit you only get Bluetooth, Handsfree and Voice Recognition, which is useless! You cannot dial via the radio, although the radio will go silent during a call. No keypad use also! Its not the same as the the factory fitted phone system. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sorry, I thought that the kit and the factory fitted were the same. So, factory fitted crap, LR kit even worse..... ![]() I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Right! ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
jmm Member Since: 06 Sep 2008 Location: St Paul de Vence/ Praesto (DK) Posts: 171 ![]() ![]() ![]() |
Well, I have the BT kit. I'm still trying to figure out the way to transfer my contacts list from my phone (motorola razr) to the integrated system.
With the BT Kit, you can only store and access numbers via the Voice Recognition System.
Bobby as of MY2008.5 the RRS doesn't have the cradle or wired system under the centre cubby box any longer, only the BT and as of MY2009 it doesn't have the Nokia system it has what LR call a "continental" system - I assume this is the Parrot built-in system.......................... the other problem now is that you have to have a cable to charge your phone from the cigarette lighter socket , not a very elegant method for a sophisticated car
Ah.. Tim, that explains it then.
just to be clear, there is no aftermarket system that will allow me to dial phone numbers via the radio interface ? |
You are right - nothing aftermarket can integrate with the radio.
Agree, the Parrot is the system to go as aftermarket (well as 1st equipment too on the RRS |
