![]() | Home > General > 275x40R20 Vs 305x35R20 |
| umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944
The recommended rim width range for a 305/35R20 tire is 10 to 12", the stockers are 9.5" wide... So you'd be pushing it a bit by fitting such a wide tire on the stock wheels. I also have the feeling you'd end up rubbing the inner front sidewall against the upper control arm, as there is already very little clearance between arm and tire with a stock setup. |
