![]() | Home > General > IPOD |
| gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176
When connecting this to the RRS aux port is the gain ok . When I connected my IPOD straight to the aux last time I needed to turn up th evolme on the RRS to over 25 to get a decent volume, ni I am not deaf!!! Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
| JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898
Not sure my self will have a go and test this if i see the RRS soon RRS TDV6 Gone but still around
| Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145
BUMP RRS TDV8, black with ivory. |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
Yeah, that sounds like the now "discontinued" ACM kit with iPod docking cradle. Same as the original kit (part # LR004805) from last year, but with an extra wire to make it compatible with the FL/LR2 as well as Disco3 and RRS. The latest kit (without cradle, just a connector in the glove box) has a different part #. I hope that's what you get, though. If they/you ordered by part # from the catalog and the kit is no longer in stock, they may send you the new one.
| RAD Member Since: 23 Sep 2005 Location: In the chippy! Posts: 309
I've got the original RR kit fitted which works well, although you have to use the iPod as the controller. Having just upgraded to the new iTouch........it won't fit in the cradle as its about 4mm taller than the 'classic'.
| All times are GMT |
