![]() | Home > Technical > Sat Nav Voice Recognition |
Voice recognition in my car was tried on the first afternoon and hasn't been used since!
| ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704
yea i only use it to show people how amusing it can be when you say one thing and she decides to do something else. |
I wonder if the voice control button is jammed in or something... it sounds like the car is expecting you to say something as soon as it turns on, which would normally only happen once you'd pressed the voice command button. Can you have a look at that and see it it can be "pinged" out with a cocktail stick or something? |
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368
Dont think so as it is intermittent, it is a TDVS 06 HSE also had LR Bluetooth after market kit fitted as pre requisite of the deal and that is also doing strange things intermmitantly, wonder if the 2 issues are connected |
| KevinJM Member Since: 16 Dec 2005 Location: Belgrade this week Posts: 120
I think you can be sure they are connected. I had an after market LR bluetooth kit installed on my 2005 TD V6 and it worked intermittently for the first year before going dead. Turned out the wiring was done badly from the unit up over the windshield to the microphone and the technician had managed to screw the sunvisor back in through the wires. You may also have button problems on your steering column. I complained about cruise control not working always and they took wheel cover off and fixed the buttons/wiring. Bring it back and ask them to check the wiring they installed. RRS TDV6 (gone)
Many thanks i think you may be correct and i am booking back in to stealer and will ask them to investigate your points. |
| 2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382
I have an intermittent issue with my cruise button not responding, was just living with it, but on the basis of this comment will contact the stealer to get it looked at! |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
I remember an old TSB concerning this.
Just had a call from the stealer and you are correct the TSB describes the exact fault i am experiencing, now booked in for new Accessory Phone Module. I will post again once fitted and let you know if fixed. many thanks to all for the help on this one |
Good luck! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Nice... it's not the first time an aftermarket install has screwed the factory wiring |
| Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
I think Shmoogle is right, in so much that the VR switch on the steering wheel is giving out signals. Next time you get in and it beeps, say in a calm voice "Radio Help". If it responds with the verbal Radio VR help then you know the system is working but the trigger isn't.
Thanks and car booked in for Friday so I will advise all re outcome. |
Sounds like you didn't get the "Matthew our electronics guy" like they have at Charles Hurst do give you the low down on all the controls! IIRC my hand over of the Tdv8 lasted something like 2 hours of which 1.5 was going through all the gizmos and controls. And I still don't use the VR! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| All times are GMT |
