Home > General > I-pod for Range rover sport |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
1 - Good choice when you take the plunge, HST rules 2. Yes to the IPod. You can either use the aux plug (which is the cheapest) and plug into your Pod or 2a. You can get LR or a.n.other to fit the rebranded Dension unit to your RRS which sits wherever you want. Mine is in the glovebox - which TBH was a ridiculous idea, as I have no idea what track is playing The permanent kit does not allow you to see the playlist etc on the head unit, but it allows control from the steering wheel buttons. Barely a solution, but it works!! We will not see FULL integration until the revised 2010 interior is launched. Hope that helps. L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
Thu Aug 07 2008 10:02pm |
nshort10 Member Since: 07 Aug 2008 Location: Glasgow Posts: 6 |
thanks very much for getting back to me so quickly.
Thu Aug 07 2008 10:24pm |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 |
RRS - top marks on wading depth - bottom of class in ICE |
Thu Aug 07 2008 11:20pm |
AustenRRSSC Member Since: 25 Jul 2008 Location: Aberdeenshire Posts: 11 |
Harman Kardonn do a IPOD docking station, it hard wires into the aux line and has a docking station, which can be fixed anywhere, it also has a 2" screen that also can be fixed anywhere. The screen has the same display as your IPOD etc. It also comes with a small dial that you use to select which song etc you want to listen too!!
Mon Aug 11 2008 9:49am |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Now............. if you all had an Audi with the MMI ... you get FULL ipod connectivity - it's like having a built in ipod
Mon Aug 11 2008 11:54am |
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 |
But what is it JC calls them? Ah yes I seem to recall Porsche Cayenne S Diesel 66 Plate |
Mon Aug 11 2008 3:51pm |
JGreg1 Member Since: 04 Jan 2008 Location: Rogers, Arkansas USA Posts: 40 |
Ok, dumb question, but I'll ask anyway. If I have my iPod plugged into the aux input, and then turn off the iPod when I turn the car off and leave it plugged in, will it draw any power from the vehicle’s battery? I would assume not, since it doesn’t charge through the aux input, but just want to make sure. |
Wed Aug 13 2008 11:44pm |
No power drain whatsoever L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
Wed Aug 13 2008 11:51pm |
Thanks Will! |
Thu Aug 14 2008 1:07pm |
