![]() | Home > General > Bike rack for RRS ..... advice please |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
That's the Aussie spec Land Rover detachable tow bar. Yes it has the green quick release knob on it and it secures to the car in exactly the same way the UK spec does, but comes in two pieces.
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
As 2nd rower states, it is the standard LR tow pack. On the actuall element where the ball is attached, you get a couple of hefty spanners and unscrew the ball. You put the cross bar on the ball mount, put the ball back through and retighten, simple as that. The A frame clips into the cross bar mechanism and is kept clear of the actuall ball itself. The only problem is you cannot stow the ball /tow hitch under the floor any more, so mine sits in the garage when not being used. The vehicle mount does not change and fits snugly in the boot space as usual. I will take some more pictures tomorrow with more detail.
MX,
MX Member Since: 06 Mar 2008 Location: Been to Moscow, beat the blues....what next? Posts: 152 ![]() ![]() ![]() |
Thanks - that looks ideal ..... are there any UK distributers? RRS TDV6 SE Java Black +towpack +tintent +Permagrin
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 ![]() ![]() ![]() |
Can't say my issue was any where near as complicated but i went for the thule roof bars and aluminium bike racks to go on top of the car. granted it's a long way up there to get them on and off but they are out of the way and I think for £300 or so I got all aluminium kit and fixings for 3 bikes.
The A bar mounting bracket is permanently attached to the Tongue, so once you have put it on, it stays on. No different from putting the tow pack on after it has been initially set up, and clipping the actual A frame in place. The actual lot cost about 120 aussie which is approximately 55 pound.
My problem with a roof mount solution is that I would need a set of rails, a set of cross bars and the MTB aero racks. When I priced them up it was in the order of £450 which is just too expensive! RRS TDV6 SE Java Black +towpack +tintent +Permagrin
