Home > Technical > Brake warning light |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
not that i am aware - light only stays on if sensor compromised - extra £12 ish to replace - if light on sensor needs replacing IMO - there is no ' reset' - as far as TDV6 is concerned.... |
Thu Jul 31 2008 10:52pm |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 |
Yes, the wear sensors on the brake pads can only be triggered once, then they need to be replaced. If the shop didn't install new ones, you will keep getting the fault light even though the pads are brand new. |
Fri Aug 01 2008 12:36am |
PEDRO PETE Member Since: 28 Jun 2007 Location: Glasgow Posts: 30 |
Thanks guys .I will give him a buzz now . |
Fri Aug 01 2008 12:13pm |
