![]() | Home > Maintenance & Modifications > 'Cheap' Replica Wheels |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
no comment until I had seen the independant government test results to confirm your comments - if they are the same product then they should perform similarly. Everything from China is cheaper |
EX-X5! Member Since: 24 Sep 2007 Location: Midlands Posts: 237 ![]() ![]() ![]() |
Yeah I'm making it up Kaine. God what is wrong with people around here the last few days. Your not on the record dude. Cant you take what I say as being right? (even just for the sake of conversation!?).
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
i suppose the replicas ain't using the same ingredients or lesser quality than that of the OEM alloys, which will result in a wheel that has not had the same safety test and stuff done on it or weaker do to the makeup of the alloy
Like F**K they do ![]() ![]() ![]() ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
Just there to make out like he's no good the man with 30 restaurants all over the world!! |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
Wheel wise , I beleive most of the LR wheels are made in Italy
On the surface, there's not a lot of evident difference between OEM and replica wheels. BUT what's important when they're supporting nearly 3 tons of car is how they have been load-tested and approved for use with such a car. While I'm sure most replicas would be safe to use for your average saloon, you really have to be a bit more serious about the load ratings in big 4x4s.
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Kaine has a point as does Shmoogle.
Did I say you were making it up? I said I would like to see the proof that the replicas were as good as the originals or better as you have indicated - I didn't say you were lying. Wheels are safety critical components and manufacturers have to cover the product liability, hence hence the price markup Next time I'll make sure I add a smilie ![]() |
John @ DW Member Since: 07 May 2008 Location: Wirral Posts: 105 ![]() ![]() |
The problem with replicas is not that they are all crap, in fact some are very good quality and as good as or better than the OE. The problem is that there are lots of very bad ones and you can't tell them them appart just by looking at them until they crack or start falling apart. Even if 2 people buy the same wheels from the same retailer you can't be sure they are the same quality as distributors can source from several factories. The reason branded wheels are more expensive is that these wheels are usually designed from scratch (extra cost) and made to pass TUV, JWL or VIA testing, then the manufacturer has to pay for the destruction tests etc. Then they market and brand their wheels and finally as they have a brand to protect they will make some losses if they have warranty issues (try taking a replica back!!). These are the reasons for the price difference and why we STRONGLY advice against reps, I could source large quantities of reps and sell them off dirt cheap, but I don't think I could sleep at night knowing some people could be at risk.
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
The load rating would be the big issue for me!
Yep, thanks John |
Thats it Jonny, why spend all that money on a really nice RRS and risk stuffing it on cheap wheels. Also you might have a problem with the insurance if they broke and you crash as they would definately check the wheels. www.designerwheels.co.uk
John - you summarised my thoughts exactly |
