| RRSPORT.CO.UK | ||
|  | Home > General > Stability control - How do I know its working? From a Newbie |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | Are you referring to Dynamic Response or traction control?  | ||
|  Wed Mar 15 2006 11:27am |
| capetoniandewd Member Since: 15 Mar 2006 Location: USA Posts: 12      | I think its called Dynamic Stability Control (DSC) button, My understanding is, this performs or gives better handling at high speeds and around corners, or am i totally misinformed?
|  Wed Mar 15 2006 11:47am |
| d3matt Member Since: 11 Jul 2005 Location: Oxfordshire, UK Posts: 730      | You wont notice anything from the DSC - only that the car handles well.
|  Wed Mar 15 2006 11:52am |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | Yes - DSC is LRs traction control offering. The usual mixture of computers and sensors that manage power to all the four wheels in low traction/wheelspin conditions. Obviously, the laws of physics still apply but it should help to avoid silly mistakes on road and of course, helps offroad (although not 100% of the time).
|  Wed Mar 15 2006 11:58am |
| Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905    | Just what you need - More electronics to go wrong  | ||
|  Wed Mar 15 2006 12:02pm |
| Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497    | DSC isn't traction control it backs the power off when it feels the car is going to loose control. As previously mentioned a slippery surface is the easiest situation to see it work. This is why many first time offroaders are dissapointed that they get stuck on a wet grassy field, the DSC backs the power off! Make sure if you go into grass gravel snow to drive on a slippy surface switch DSC off. Once you are used to it you find that you don't need to unless you get real slippy conditions. | ||
|  Wed Mar 15 2006 12:04pm |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | A system that backs power off of the driving wheels when it senses wheel slip IS traction control, surely?  | ||
|  Wed Mar 15 2006 12:12pm |
| Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497    | No it's not really slip it senses it is side to side motion more that is easily recreated on slippy surfaces. TC uses the ABS to damp the braking on the wheel. If you drive across mogul type obsticles where a wheel is lifted in the air you will see that wheel turn in a jerky fashion as the TC stops it. DSC backs the power off as it senses you are going to crash by erratic movements. If you switch DSC off TC (not turbochip) will still work fine. | ||
|  Wed Mar 15 2006 12:46pm |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | OK, I didn't realise that was particularly the case  | ||
|  Wed Mar 15 2006 1:19pm |
| chex Member Since: 06 Mar 2006 Location: UK Posts: 210  | ooh
|  Wed Mar 15 2006 2:42pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Can I butt in here..............
|  Wed Mar 15 2006 2:53pm |
| chex Member Since: 06 Mar 2006 Location: UK Posts: 210  | good info =)
|  Wed Mar 15 2006 2:55pm |
| Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497    | Yes they did! | ||
|  Wed Mar 15 2006 3:04pm |
| chex Member Since: 06 Mar 2006 Location: UK Posts: 210  | O.o
|  Wed Mar 15 2006 3:28pm |
| Posting Rules
( I did also say it doesn't help offroad 100% of the time!
  But is it not also the job of DSC to react to slipping wheels in the more traditional sense? This works in partnership with EBD to help you going hedgebound in onroad situations? This is certainly how it works on other marques... I'm assuming it's the same for LRs...
