![]() | Home > Technical > Knocks when turning the wheel? |
The knocking is probably the most reported issue on this site. There is no definite solution, although some of the solutions you have read about should at least be tried - they seem to work in the short term for some people.
If you have the RRS in access height this happens. 2005 Zambezi TDV6 - Gone but not forgotten
...you veer off the road and kill yourself? |
| Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054
Could be the Dynamic knock - no cure or could just be that the steering bumps need adjusting so that the wheels don't touch on full lock or your bushes need doing again.
No the knocking noise - numpty! 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed.
WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
| sapkan Member Since: 22 Feb 2006 Location: Bg Posts: 16
It doesn't happen in access only, it occurs in normal ride height too. Its not the steering bumps as it doesn't happen in full lock only but also when turning a little. Also the steering bumps were greased when I had the dynamic response knock rectified. It is more of popping (4-5 pops) than knocking sound, I have a feeling it is steering related but I am not 100% on this.
Sound like you will have to take the 600km drive to the Dealer. Or find one closer before you go. TDV6 - gone
| pers1 Member Since: 22 May 2006 Location: Heggedal Posts: 35
I had the same problem and LR in Drammen change the front ball joints after this problem! Just got it fixed 2 weeks ago! It seems to be fixed! PerS RR SPORT TDv6 HSE 2007 Buckingham Blue Ebony Interior American Straight Grained Walnut Dynamic Pack HSE Rear Diff. 20 inch Stormer alloys Privacy Glass Premium ICE Pack Hybrid TV Personal Telephone Integration system Tow Pack Brembo Front Brakes Bi Xenon Adaptive Head Lights ADDED on delivery Grille – perforated with "Titan" finish in buckingham bllue Twin oval tailpipe finishers Stormer side vents with "Crome finish" |
| All times are GMT |
