![]() | Home > Technical > Where do the electrics Plug in for Towing? |
| Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555
Flight they are located under the rear tray, you have to use a screw driver to remove the cover but be prepared to replace the screw because the little |
| flight Member Since: 24 Jan 2008 Location: London Posts: 186
Thanks....
| Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939
Flight - Have a look at the following picture :
thankyou
| Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355
If you mean the plug socket adaptors that go into the LR towing kit and feed the tow bar electrics - they are behind the nearside trim panel in the boot.
| theo Member Since: 04 Jun 2007 Location: Netherlands Posts: 12
And be carefull with the f****** unbelievable thin plastic screws. I've used them 3 times and now I have 4 pieces.. |
The "secret" technique to use to avoid damaging these screw fittings is to only ever turn the screw after carefully ensuring the screw is correctly located and orientated in the hole and whilst applying lots of inward pressure to keep the screw in said hole. This is necessary to ensure the spade end of the screw fitting has cleared the edge of the receiving hole. If you try to turn the screw against the edge of that hole it will almost certainly break. RRS TDv8 HSE Rimini Disco 4 TDv6 HSE Ipanema Defender 90, 200tdi CSW |
| TheVerb Member Since: 12 Aug 2010 Location: Yan Yean Posts: 17
Does anyone know if the RRS fitted with factory tow kit can control a trailer (horse float) fitted with electric brakes? |
