Home > General > Front indicator problem - really peed off...
Diablo
Gents,
I got my car back from the bodyshop last week (colour coding etc). When I collected the car, the front NS indicator wasn't working. I finally got around to getting a bulb yesterday and having a go. I changed the bulb but it still did not work. Pulled it apart again (managed to scratch the bumper with the grille Evil or Very Mad ) and tried another bulb. Still no luck. I then checked the wires going into the multi plug and they all seem to be OK. I have now checked everything I can, so does anyone have any other suggestions??
Any suggestions will be gratefully received.
Post #169930 Sat May 17 2008 7:32pm
Fuse? If not get it sorted under warranty. 2005 Zambezi TDV6 - Gone but not forgotten
Post #169933 Sat May 17 2008 8:57pm
Diablo
It will go in under warranty.
Post #170075 Mon May 19 2008 2:18pm
Murdered out
United States 2008 Range Rover Sport 4.4 V8 HSE Java Black
The probably broke a small metal piece that is welded on the bulb holder. it makes the connection between the circuit. If the little metal bead is missing from the holder thats your problem. Its common if you take your bulbs out a enough.
Post #170364 Wed May 21 2008 7:16pm
