![]() | Home > General > Towing with the "get you home spare" |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I presume its a full sized spare? not one of those thin wheels
SteveWilliams Member Since: 05 Aug 2007 Location: Swindon Posts: 138 ![]() ![]() ![]() |
I have just had to put my spare on as some nice person thought it would be fun to make a hole in my tyre wall. I also have 20" tyres but the spare is a 19" which says limited to 50 mph. Driving at that speed on a busy M4 is not something I would recommend so kept my speed the same as HGV's at around 55 mph.
CJ Member Since: 29 Apr 2007 Location: Sunny Sussex Posts: 18 ![]() ![]() |
The spare is indeed a 19" full size but not a steel wheel, it is black but looks very much like a reinforced plastic. D4 3.0 HSE with all the toys.
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
It is painted metal for sure. Likely steel no? 2022 P440e AB |
I thought it was a black alloy.............................. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
It's an OEM wheel, so whatever it's made from as long as you stick within the posted limits it should be perfectly fit for getting you home, I would've said. Just keep your speed down, especially if there is extra load |
OEM black alloy yes, proper tyre yes, same rolling radius as 20" so why the restriction? No mention of it in the hand book, have contacted the local dealer and they couldnt give me the answer!!
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
It is a black, 19" alloy the same as fitted to some HSE D3s, if you look at the load rating on the wheel it is higher than the 20" 10 spoke alloys on the RRS. The rolling radius is slightly greater than the 20" maybe that is why the lower speed rating? Sons of dogs come hither and get flesh
