![]() | Home > Technical > Transmission failure! |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
On the way into work this morning my less than1 month old RRS starts beeping and delcaring "Transmission Failure", I tried slipping it into Sport or Manual and it wouldn't go....
gadgetJunky72 Member Since: 31 Jan 2008 Location: London Posts: 37 ![]() ![]() |
There are a few instances of these sorts of things happening - sometimes they are false positives, sometimes they actually do relate a problem that has occurred. Always worth getting them checked out if you can though. |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
Intermittent HDC faults were happening in my car, particularly when left overnight in the cold... Do they happen mostly in the morning and only once. switch the car off, start up again and no fault? A few sensors were changed out but the problem remained. A change of a battery (my idea ![]() ![]() HDC is not transmission really.... It is Hill Descent Control which mostly (only?) uses the car's brakes. 2022 P440e AB |
