![]() | Home > Technical > Computer Reset when i Start the thing up. |
| kljw Member Since: 01 Aug 2006 Location: Edinburgh Posts: 117
Hi
Does it happen everytime you start? And then only at start time? |
not every time i start, on occasion. |
It isn't right, whatever it is.... the reason for my question was that I was thinking maybe it was a fault that occurred only in particular temperatures (e.g. when it's really cold in the morning etc). Best take a trip to your dealer to get it checked out |
think i will. no set temp range and purley random. the only constant is that when i start the engine, the centre display goes off and resets.
| Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980
Ok, is this happening when you put the key in the ignition, the systems start up but if you then start the car before it all comes on the systems go off and re-start again. Speed Limits! not where I live!
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
us Fl2 owners have a similar problem
| All times are GMT |
