Home > Technical > Squealing brakes!
RRSSS
Bahrain 2010 Range Rover Sport Supercharged Nara Bronze
Squealing brakes!
Hi guys,
Just wanted to pop a question out there before I go to the dealers..
I've now done about 8000kms (5000 miles) and have recently noticed that on slow speed braking (ie. stop start traffic), my brakes begin to squeal (quite loudly at times Embarassed ).. Have the pads had it already??
Anyone else with similar issues?
Thanks!
ps. It's getting so bad I might need to start telling people I've got carbon ceramic brakes on!
Post #155813 Thu Feb 14 2008 5:47pm
Japseroony
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
I have the same problem with mine and its only done 2000 miles, its going in for them to inspect the alloys tomorrow so will ask them to check this at the same time and report back on Sat.
Russell. "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #155819 Thu Feb 14 2008 6:58pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
My car had this exact issue from about 8k miles and TBH I put up with it until very recently, having now covered 22k miles. It took a few attempts mind:
1. They changed the brake shoes for the handbrake (I assume its shoes?) which did not work.
2. Then they adjusted the shoes as they were suspected to be dragging, this also did not work.
3. They have now replaced the rear disc pads and it seems to have cured the issue. The SB issued regarding this states that screeding the pads should remove the squeak, but my stealer deemed that pointless and replaced under warranty. All, so far, is quiet!! Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #155997 Fri Feb 15 2008 5:55pm
RRSSS
Hmm, I was kinda hoping it was a lodged pebble or something.. oh well, off to the dealers..
Japseroony wrote:
Russell.
Look forward to your update!
Post #156002 Fri Feb 15 2008 6:23pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
the D3 site has a section devoted to the Brakes in particular the Park Brake issues which can cause problems. My brakes have started to squeal again after the EPB was fixed late 2007. With all the other faults its all becoming quite depressing Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #156151 Mon Feb 18 2008 11:36am
RRSSS
Japseroony, any news on your situation??
Got mine booked in for Tuesday.. brakes, slight vibration on speed, and the sliding thing for the cupholders seems to be stuck!
aaah, the reality of ownership seems to be kicking in now..
Post #156864 Sat Feb 23 2008 8:14am
Japseroony
Had mine in and they said they fixed it but after getting it back it still has the same problem Exclamation Exclamation
As its got to go back for yet a further radio to be fitted and also for them to have a 3rd look at the alloys (which are scratching too easily) I am going to ask them to have a further look.
I kind of think they dont know what they are doing but are very plesant about it Exclamation Exclamation "UNDERSTEER" ----is when you hit the fence with the front of the car.
Post #157175 Tue Feb 26 2008 10:46am
RRSSS
Just a quick update on the brakes issue: (apologies for the slightly long rant)
Got the car back a couple of days ago (they had it for 4 days), and all they did was the first service and apparently a recall done on the tyres (?) There was a flat spot, so they replaced all the tyres Smile never heard of that, but didnt complain!
Most importantly though, they didnt touch the brakes because there was some misunderstanding that I didnt agree to pay for it (I told them it was supposed to be under warranty, as I've only done 8000 kms). So they called the After Sales Manager (who happened to be British) and I explained everything to him, he finally agreed to have it done FOC Thumbs Up They are basically going to polish all 4 discs and this should cure the problem.
His explanation is that LR is aware of the squealing brakes, and is currently working with Brembo to find a solution. He also mentioned that this might reoccur in the near future (ie. after a few thousand more kms) Sad
Oh well, back to the dealers next week..
Post #158104 Tue Mar 04 2008 6:06am
