![]() | Home > General > First Edition - very early model (May 05) |
Lemm, what I'm saying is that most faults either have an available fix (under warranty) or that more recent MYs have the new bit or improved functionality built-in. While I'm not sure it's reasonable for you to suggest that the car is brought up to the levels of a new RRS in terms of fixes/upgrades etc, there are a few things you could check have been done - replacement wipers, PDC upgrade, BT upgrade? |
lemm Member Since: 03 Jan 2008 Location: London Posts: 135 ![]() ![]() |
not sure where the old hospitals once were... would it be just off Chessington Road?
shmoogle... i guess most the the main bits of the car would be the same... the edges might have changed, but the main grunt of the machine would not have changed to much (i hope) |
Yep, you're right. It's basically the same car (but without a clock in the instrument cluster, for example |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Typing at the same time it would appear ![]() |
