Home > Maintenance & Modifications > TD Chips - Just more boost? |
Not the best or safest way to simply increase the boost pressure, but this can be achieved with some cheapo plugins. Best to get remapped... there are a few threads relevant to the Oz market if you search
Mon Jan 28 2008 1:06pm |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
Increased boost will give no more power without increased fuelling to suit. Older TDi engines could have the injector pump tweaked to provide more fuelling to suit any adjustment to the wastegate that increased the boost but on a modern common rail injection system such as the TDV6 youŽll need to remap the ecu to provide extra fuel along with the extra boost. Cheers
Tue Jan 29 2008 10:11pm |
Damn Member Since: 28 Jan 2008 Location: Melbourne, Australia Posts: 7 |
Really? If you were to take any EFI petrol engine from the 90's all the way through to now, they all would increase fueling when boost increase, either electronically via the injectors or mechanically via a rising rate fuel regulator. I can't believe a new diesel engine will just ignore the additional air going into the engine and let the whole thing lean out |
Tue Jan 29 2008 11:52pm |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 |
If you try and increase the boost pressure manaualy the car may hit a boost limiter and go into limp mode on overboost.
Thu Jan 31 2008 9:55pm |
Certainly a possibility. Toyota turbo cars usually have a boost cut which is only a few psi higher than stock, so even an exhaust & cooler swap can get you hitting it. Nissans are usually higher, you can wind the boost up a fair bit before hitting boost cut.
Yeah as would a free-flowing exhaust (although I doubt people are buying RRS's to but large garbage can style exhausts like the youngens do to their Skylines)
Sounds like it. Has anybody here done any tuning, either map re-writing or via various piggyback style ecu's, of petrol or diesel engines? With diesel engined cars becoming more and more popular I wonder how long before diesel performance workshops will pop up on every corner? |
Thu Jan 31 2008 10:32pm |
Ive done plenty of map writing on these engines and many others also. |
Thu Jan 31 2008 10:38pm |
Excellent What's your experience like specifically for the RRS TDV6? What is standard boost? Where have you found the boost cut to be? Do you only custom write chips or are you selling them pre-packaged? If so do you have an Australian channel / outlet / reseller? |
Thu Jan 31 2008 10:48pm |
Petrols control power output by limiting the air taken in, the mixture must then stay within quite close limits. Diesels on the other hand run with full airflow all the time, power output is controlled by the amount of fuel injected, consequently a diesel cannot "lean out", power output will simply reduce.... ...so increasing the boost means the diesel engine will flow more air but wonŽt be able to generate any more power unless more fuel is injected than before. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Thu Jan 31 2008 11:28pm |
Hummm, ive started something i did not intend here .
Thu Jan 31 2008 11:33pm |
Thanks for your post simonsi - I've not played with a diesel before
Thu Jan 31 2008 11:39pm |
The rail runs at a fuel pressure of 1650 bar on the 2.7L model.
Fri Feb 01 2008 12:01am |
1650 bar That's 23,100psi! WOW. |
Fri Feb 01 2008 12:05am |
Yes high, most modern CR piezo diesel type injection systems can run high pressures of up to 2000 Bar.
Fri Feb 01 2008 12:16am |
A bit of reading on the boost system for you .
Fri Feb 01 2008 12:41am |
