![]() | Home > Tips & Tricks > Bluetooth pairing code (2121) does not work |
| Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902
Hi 'tang,
| Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95
Cheers Kaine,
the main reason I stopped using mine - too many hard resets required good luck |
| joka748 Member Since: 28 Nov 2007 Location: Hampshire Posts: 63
Try 0000 and see if you get any further.
Well, i just braved the rain to go try 0000 and you're spot on - it works perfectly.
Did you manage to download your contacts to the vehicle system and dial numbers from the keypad on the radio? To download your contacts you need to be able to 'push' them via OBEX (object exchange). |
I've got the after-sale PTI so I only tested using the car as a headset. From what I've read in other posts I'm not even going to try pushing the contact as I'll only end up depressed when it doesn't work... |
Yeah, the dealer PTI kit is a bit disappointing... didn't know about the 0000 code though, thanks for that! |
