Home > General > PTI and iPhone problem - anyone suggest a solution please?
Page 1 of 3 123>
Peter
United Kingdom 2006 Range Rover Sport SDV6 Autobiography Java Black
Hi Guys.
I was bought an iPhone for Christmas and now have it activated etc. It does connect to the RRS PTI via Bluetooth but not automatically! Each time I get into the car I have to go to the iPhone menu Settings/General/Bluetooth and can see they are paired but the PTI on the car reports no phone attached.
If I un-pair them in the iPhone menu and then re-pair by entering the 2121 code it works fine. Is this normal?(Apple says it is). My Nokia N76 would automatically connect with bluetooth whenever I was in range with the car every time. Apple says that they will not auto -pair.
I have never been able to scroll through the address book via bluetooth on any phone used in the RRS.
Or is this maybe a solution that the RRS bluetooth (chargeable) upgrade will fix? Again it annoys me that I should have to pay a "stealer" to upgrade my bluetooth software when he gets all his PC's Operating Systems upgraded free by Bill Gates whenever it is needed!! It's finally gone! Replaced with BMW 730SE in Sophisto grey Xirallic finish with Oyster (Ivory) and black interior. DAB, Climate glass, Ceramic iDrive and gear selector, power boot and iPhone Bluetooth pack - luvvin' it!
I miss my old RRS "bucket" rattling around but it just had to go!
Post #151361 Fri Jan 11 2008 10:50pm
PauloAmore
Scotland
Err, not a solution, but mine does the same.....
Anyone have an iphone that works properly on the PTI?
- Sounds like we need our bluetooth upgraded. 2022 P440e AB
Post #151497 Sun Jan 13 2008 6:23pm
There are others who have said that it does work the same as your average Nokia... phones paired with the PTI should automatically reconnect once you've been through the initial pairing.
Post #151553 Mon Jan 14 2008 10:56am
Jimmy_75000
Same issue there, seems that I have to re-pair the car and the iPhone after I have either switch the iPhone off or shut bluetooth off on the iPhone. If I keep the iPhone on all the time with never switching it off, I have no problem in the car....
I believe it is an issue on the iPhone side as the bluetooth fonction on the phone is more restricted than on other phone. A software update is expected for the iPhone in the next couples of days so maybe this will solve the issue.
!! Warning: if you have unblock your iPhone to use any simcard and/or install 3rd parties software, do not install the future update as this will reblock your iPhone and removed 3rd parties softwares. Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #151576 Mon Jan 14 2008 12:09pm
Peter
Thanks to all of you who replied to my query.
I hope that the iPhone update expected soon will do the trick It's finally gone! Replaced with BMW 730SE in Sophisto grey Xirallic finish with Oyster (Ivory) and black interior. DAB, Climate glass, Ceramic iDrive and gear selector, power boot and iPhone Bluetooth pack - luvvin' it!
Post #151680 Mon Jan 14 2008 8:20pm
PauloAmore
Scotland
Did you upgrade to iphone firmware 1.1.3?
- If so, did it cure your iphone connection issues?
I am having my PTI upgraded next week. Will let you know how I get on. 2022 P440e AB
Post #154626 Tue Feb 05 2008 6:23pm
JJF701
I upgraded my iphone to 1.1.3 and it made no difference at all. Keep us informed after the pti upgrade.
Post #154661 Wed Feb 06 2008 2:57am
fernandez77
ez now
my iphone was working fine until i upgraded to version 1.1.3 and now land rover say thats what the problem is,
if you google it , it looks to be true too
Post #154942 Thu Feb 07 2008 9:25pm
Censored Evil or Very Mad Evil or Very Mad RRS TDV6 Gone but still around
Post #154945 Thu Feb 07 2008 9:28pm
landroverstormer
England 2006 Range Rover Sport TDV8 HSE Java Black
I'm on 1.1.3 and currently drive an 08.5my and it works fine as regards BT connection and phonebook. Not checked any other functionality though. Not sure if this helps? Shocked TDV8 HSE in Java/Ebony with Zebrano Wood, RSE, Hybrid TV, and a few other bells and whistles.
Discovery 1 V8i Auto (The Off Road Toy)
Post #154961 Fri Feb 08 2008 7:41am
JJF701
Looks like we need to upgrade the PTI upgraded to the 08 software then. Never heard anyone say it works with the phonebook before so PTI software must be the answer.[/code][/list][/quote]
Post #154976 Fri Feb 08 2008 12:41pm
I was in the apple store the other day and i ask the guy how to send text tones over from my N95 to the iphone? He said i can't BT on the iphone is only for the headset and not anything else RRS TDV6 Gone but still around
Post #154982 Fri Feb 08 2008 1:39pm
Lookers Park Royal
Mine works! Whistle
Click on this link http://www.landrover.co.uk/gb/en/Vehicles/...ration.htm and download the relevent listing for your chassis number (recently updated to include iPhone).
Mine works fine with the phone directory and connects via Bluetooth every time I get in, however I don't remember the other functions working. I am on 1.1.3. The first time I paired it it didn't work..... what you need to do is pair it, call someone, and whilst in mid call select Land Rover on the screen for your chosen output (otherwise the call will be via the handset), and once you do this the first time it will be set! It did take a second or so to swap from handset to Land Rover so be patient. On the iphone you can select, handset, speaker or the Bluetooth device in mid call, so it looks like you have to tell it the first time even though you've paired it. If anyone needs talking through it then pair your phone, sit in the car and call me on 0208 992 2299!
It is possibly an iphone thing in so much as things work slightly differently to a normal mobile, as currently I can't forward text messages or send/recieve pictures via picture messaging. Crying or Very sad
Hope this helps?
James Thumbs Up
Post #154985 Fri Feb 08 2008 2:16pm
Is it a free update???? Mr. Green RRS TDV6 Gone but still around
Post #154989 Fri Feb 08 2008 3:49pm
Lookers Park Royal
Jay,
Free updates is a topic that has been covered once or twice before! On a serious note I'm not sure if an update will work as it is chassis specific? Will let you know if I hear any news from HQ.
Post #154992 Fri Feb 08 2008 4:25pm
Page 1 of 3 123>
