Home > Technical > Too Many Beeps ! |
ST Member Since: 26 Oct 2005 Location: Leeds Posts: 411 |
I too find the random beeping somewhat annoying, although after 6 months of ownership my brain has zoned them out now. In my experience it is either the PDC or the temp droping.......
Tue Feb 28 2006 1:56pm |
There's a beep for every warning or information event. Aside from the annoyance of the front/rear PDC going mental at random intervals for no apparent reason, you should find that with most beeps you get a little "i" pops up on the message centre. If you then use the "i" button to scroll through the displays, you should see what the last message was. I have one at the moment because my washer fluid is low...
Tue Feb 28 2006 2:01pm |
Never noticed the 'i' popping up - will look out for it at the next beep......
Tue Feb 28 2006 3:22pm |
Can't say if you get the i on your D3, but if def appears on the RRS. Assume it would be the same. You don't get an i for everything though - i.e. the 4deg beep doesn't produce an i but you get a little flashing snowflake next to the temp. Very wintery!
Tue Feb 28 2006 3:30pm |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 |
Came across this this morning www.sexydesktop.co.uk |
Tue Feb 28 2006 3:42pm |
stuart2u Member Since: 02 Feb 2006 Location: Nottingham Posts: 24 |
Speaking of Beeps.........I have set the 'overspeed' warning thingy as I have done on previous vehicles and expected it to warn me when I reached the predetermined speed. It does in 2 ways; a note in the 'i' panel, which is a fat lot of good when travelling at 80....and a 'Beep' which I can only tune into with all music off, the wife muffled and no road noise.....in other words impossible to hear. Do you know how to increase the volume of the 'Beep' please.
Tue Feb 28 2006 3:49pm |
vip-culture.com Member Since: 12 Feb 2006 Location: The OC Posts: 86 |
my disappointment is the lack of visual aid for the PDC...it just beeps and the thing is all the beeps sounds the same...well the front sounds different than the rears but there's just too many. www.vip-culture.com | 06 RRS HSE | 06 Odyssey Touring
Wed Mar 01 2006 8:45am |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2579 |
I don't think its possible to increase the volume of the beeps Stuart2u.
Wed Mar 01 2006 10:20am |
Yes, I've fallen foul of this. It's for this very reason I dinked my rear bumper after 2 days of ownership. Much preferred the BMW system where you get a picture of the car and highlighted regions where you're in danger of collision.... 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
Wed Mar 01 2006 11:01am |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 |
I have had my RRS since the end of august, so just over 6 months now.
Wed Mar 01 2006 2:18pm |
Robbi Member Since: 14 Jun 2005 Location: Channel Islands, Guernsey Posts: 130 |
Think I read somewhere that the PDC can be set off by stray signals of certain frequencies....or could be total b*llocks. I get the odd bleep for no apparent reason.
Wed Mar 01 2006 10:51pm |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
The PDC sensors are ultrasonic and may be impacted by stray noise/frequencies, especially from large trucks or loud motorcycles. It's not perfect. If it really bugs you, tap it off while driving and turn it back on when you need it. |
Thu Mar 02 2006 12:11am |
stwsam Member Since: 10 Jan 2006 Location: hershey, npa Posts: 7 |
notice it often gets stuck on at a stop when a good rain is falling. Assume water droplets are hovering on the sensor. Also, yes, any time large rigs pull up next to me at a stop, the pdc lets me know the reason the sun just went away is because I am next to a tractor rig. maybe the car is just nervous!! |
Thu Mar 02 2006 3:23pm |
I do like the 'fix' for the seat belt warning bong.......
Thu Mar 02 2006 9:53pm |
