![]() | Home > General > Automatic Start??? |
| Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355
It can be fitted over here as part of an aftermarket alarm system, Clifford and other suppliers etc all offer it as an option to go with the alarm being fitted to the car.
| Phantom Member Since: 20 Oct 2007 Location: Belgium - Ohain Posts: 102
But how would that interact with the memory?
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
This is how a US owner did it (basically you'd need a third key): http://rangerovers.net/forum/viewtopic.php?p=154831&start=16 |
When the key is inserted it is recognised as the one programmed to the car. The key reader transmits the data from the key which has to match. To activate this you would need a third key programmed to the vehicle and hidden away so that it was read on the start sequence before entering the one in the ignition, once the vehicle has started it ignores the signal from the key, obviousley because of high speed failure etc while driving. So as long as it reads one with the correct option code for that car first, it doesn't matter what you put in the ignition after, once the engine is running. Hope this is ok for you to understand. You don't stop playing because you get old, You get old because you stop playing. 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
All clear, thanks |
| All times are GMT |
