![]() | Home > Technical > DVD troubles |
| JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898
Know this is silly but you are loading them in to the mag in the boot right and not the dash? RRS TDV6 Gone but still around
| berommen Member Since: 15 Dec 2007 Location: Roeselare Posts: 11
Yes , artwork facing up, evreything like it should be.Tied several different DVD's. |
Not sure sorry never seen that message myself!
I wonder if one of the cables has been disturbed and might loose or unplugged - have you checked all the connections in the boot? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I'm not shure about that , they are not easy accesible. I guess I better take the car to my dealer to check that out. Thanks for the reply's. |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
Just a thought...
Makes sense Bobby |
The car is a Belgian car and I tried 10 different dvd's with the european region code.I have my car back tomorrow evening, I hope they(dealer) found the solution. I will keep you informed.Thanks for the reply's. |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
Probably too late, but this is from an old DVD troubleshooting bulletin.
Check to make sure you are not in the wrong video format using the remote (e.g. NTSC and trying to play PAL encoded discs) as per bold note above... It may be as simple as that. The On/Off button is the small one on the upper left side of the remote. Good luck, keep us posted!
Hi. Today I got my car back from the dealer. They can't give an answer to the problem with the DVD player.So they contacted land rover and an expert will come to the dealer and will check out what is the problem. I will keep you posted but I have the impression that this will be a difficult one... |
"• Press and hold the On/Off switch at the side of the remote control to
| All times are GMT |
