| RRSPORT.CO.UK | ||
|  | Home > Technical > Windscreen washers |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104      |
 Anyone had a problem before with front and rear wash jets not working? Headlight jets work but front and rear screen jets dead.    | ||
|  Tue Dec 18 2007 5:37pm |
| cowey101 Member Since: 17 Jul 2007 Location: Gods country! Posts: 403      | Are they not just frozen?   | ||
|  Tue Dec 18 2007 5:40pm |
|  Tue Dec 18 2007 5:43pm |
| Phantom Member Since: 20 Oct 2007 Location: Belgium - Ohain Posts: 102      | They are supposed to be heated, I'll test mine tommorow morning, it's freezing nicely over here   | ||
|  Tue Dec 18 2007 5:56pm |
| bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336    | how do you get the rear washer working?! | ||
|  Tue Dec 18 2007 6:17pm |
 I think you pull the stalk don't you - i do it without thinking - if no one else chirps in i'll go out and check.   | ||
|  Tue Dec 18 2007 6:20pm |
 Cheers   | ||
|  Tue Dec 18 2007 6:21pm |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104      | Cheers Tim !     | ||
|  Tue Dec 18 2007 7:01pm |
| db Member Since: 28 May 2007 Location: London Posts: 19    |
 yep mine have failed also...the windscreen washers I mean  | ||
|  Fri Dec 21 2007 12:24am |
 http://www.rrsport.co.uk/forum/topic1057.h...en+washers
|  Fri Dec 21 2007 12:32am |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104      | Nice one db - this had crossed my mind i just hadn't got around to opening the manual to find out where they were etc   | ||
|  Fri Dec 21 2007 6:59am |
| Phantom Member Since: 20 Oct 2007 Location: Belgium - Ohain Posts: 102      | Forgot to report back, mine were working with -6°C outside, so they are heated but you do need to wait 1min before they will work. 08.5 RRS TDV6 HSE Java Black/Alpaga - Cold Climate Pack - Privacy Glass - Bluetooth - Sunroof - 20" wheels - Rubber Floor mats.
|  Fri Dec 21 2007 8:58am |
 Its the fuse alright....
|  Fri Dec 21 2007 7:13pm |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104      | Done! - what designer placed the spare fuses there   | ||
|  Sat Dec 22 2007 2:55pm |
| Posting Rules
 well - thought that but temp has been up to 5 deg and still inop - would the headlamp jets not also be frozen if that the case ?
 lazy
 lazy
 spare fuse flipped out and ended up down the back of the trim ?!?!?! had to take trim out to get to it ............................
