![]() | Home > General > Multi height tow bar removal |
| j8keyboy Member Since: 09 Oct 2007 Location: Loughborough Posts: 37
All,
| TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927
I don't think you'll get many takers for the swap.
OK so I take it the detatchable tow bar is more desirable then!
| Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208
Remove it as you stated, take the 2 bolts out of the chassis (you may have trouble re aligning these when they go back in, it may help to loosen the nuts on the outboard side to allow the part inside chassis rail to move a bit.), loosen the nuts and bolts at the bottom end of the struts or remove them completely,and then use key and unlock, pull out and turn the green knob on the part that connects in the receptacle and drop it down, ( watch out though, its heavy). |
I don't think I have ever seen one on an RRS, the local farmers have them on their D3's around here, I would imagine that you will have to get underneath the car to see where it is bolted onto the rear subframe/ chassis. Have you tried asking over on the Disco3 technical Forums? www.disco3.co.uk 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
| Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497
Once I get the tow bar off how much should I expect to sell it for on ebay do you think?
The removal is easy, just make sure you have the key. It is 2 bolts and the locking mechanism in the reciever. I paid over £200 for mine new, they don't come up very often. I'd try posting on the D3 site first. |
| All times are GMT |
