![]() | Home > Maintenance & Modifications > Heater |
The car should have a built in fuel burning heater............................... except that some early cars had them missed out on the line |
Have a look at this thread on our sister site.
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Just checked on my MY07 HSE and it has a silver box with a Webasto sticker on it just behind the 3 fluid bottles. It's approx 5 x 5 Inches square with a couple of foil covered pipes connected to it, If that's the FBH then they do still have them. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
klm Member Since: 30 May 2006 Location: UK Posts: 155 ![]() ![]() |
Yep my TDV8 sport has one of those silver boxes, so are we saying this company can do a remote or something that can turn the heaters on in the car??? |
If I remember it isn't a remote control, more of a timer unit, so you set it up to switch on at a certain time interval before you want to use the car. Normally the FBH will only cut in without the timer when the airtemperature drops below 5C. It is basically there to counter the high thermal efficiency of the ferrous graphite engine block which takes a huge time to warm up the air under the bonnet even on really cold days. Even with the FBH my RRS still takes about 5 miles driving before I get warm air out of the blower, my Defender is blowing hot air within a mile of leaving the house! On very cold mornings you shouldn't be alarmed if you see a small whiff of smoke coming from the front airdam - it is the FBH exhaust! When I had my Freelander1 I called the dealer thinking there was a fault under the bonnet causing the engine to smoke the first cold morning I experienced this! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
R22Flyer Member Since: 04 Feb 2007 Location: South Posts: 114 ![]() ![]() ![]() |
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 ![]() ![]() |
But it only warms the engine, it doesn't blow the heat into the car |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
I would be interested in the remote, the timer would not be much use for me. '08 RRS TDV8
Hoye Member Since: 15 Dec 2007 Location: Tvedestrand Posts: 20 ![]() ![]() ![]() |
I just spoke with Webasto. They have still not made any upgrade kit for the heater i.e we will not be able to control it as we want (remote etc)
