![]() | Home > Technical > Sediment trap ? |
| Working Dog Member Since: 29 May 2007 Location: In the hills Posts: 193
A mate who has a TDV6 is off the road at moment due to a suspect load of Diesel.
News back from Land Rover. Water contamination in the fuel - $12,000 to fix!!!
WD, have you had it confirmed that this no longer exists on the D3/RRS? Seems strange to me they would take it away if it serves such a purpose |
Hi Shmoogle
| stephenw Member Since: 12 Nov 2006 Location: Canberra ACT Posts: 91
WD, I just had my vehicle serviced and confirmed that the RRS has NO sediment trap. Trivett in Sydney have two of their own vehicles off the road because of engine damage from water in the fuel. They are discussing with LR ....
Hi Steve,
Thanks mate.
Steve,
This is interesting as I think my car has this problem. My RRS is currently waiting a a flush out. I'll let you know the outcome. 2005 Zambezi TDV6 - Gone but not forgotten
| KevinJM Member Since: 16 Dec 2005 Location: Belgrade this week Posts: 120
Dealer wants to do same with mine, take tank off and flush out. hasn't said it's water contamination but just dirty fuel. Mine's an 05 MY so no bells and whistles on the message centre. To add insult to injury, the factory fitted sunroof now leaks and the driver side was soaking wet this morning No visible damage to roof seals which makes it even worse. RRS TDV6 (gone)
Kevin, open the sunroof and check that the track drains are not blocked with a dead leaf, a spider's web or some other debris. This is usually the cause of a leaking sunroof on any car. I'm not familiar with the sunroof drains on the RRS but when my Freelander suffered this problem the dealer showed me what had happened. It is also possible that debris has travelled down the drain line in the A pillar in which case the dealer will have to unblock it as there is an airbag in there too! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
Thanks Tim, I'm off to have a look again now. Given the amount of water that came in I am amazed that there is no water staining on the overhead sections. A dry cloth pressed against it soaks all the water out almost instantly. I'll have a look around the drains and see what's to be seen. RRS TDV6 (gone)
I've been there and back. The drain holes are clear as far as I can see and the whole area around them looks clear. However, the channels themselves are very small and a combination of parking on an incline (nose down and to the left) , torrential rain over the 14 hours the car was parked and the roof maybe not having full locked forward, may have simply allowed too much water to build up to get out the left hand drain. Or maybe I am too forgiving. Anyway, this the wrong thread so cheers. RRS TDV6 (gone)
Where did you find a hill steep enough in Holland to have this experience Kevin? |
| All times are GMT |
