Home > Technical > Juddering Wipers: Finally!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Left one is ok but the right one Mad RRS TDV6 Gone but still around
Post #137366 Wed Sep 12 2007 8:12pm
Lateral5
Australia
Had mine replaced with the ones in the tech bulletin and no problem since. Also, the mechanic put a slight twist in the arm with a shifting spanner.....primitive yes, but it worked! Thumbs Up RRS TDV6 Bluetooth, VR, Roof
Post #138967 Sat Sep 22 2007 1:15pm
nigelkippax
Even cheaper! With Premium ICE, just "turn it up to 11"!!!!!!!!!!!!!!!!!!!!!!!!!! Laughing Laughing Laughing Laughing Mr. Green
Post #139296 Mon Sep 24 2007 8:22pm
KenD
England 2007 Range Rover Sport TDV6 SE Zambezi Silver
Had the new wiper blades fitted (blades only not arms) by my stealer and guess what, SILENT, after 4 attempts success. What differtence now I can turn down the radio.
It looks as though the guy at LR was right about the Bulletin and the latest update.
So if any of you still have chattering wipers, get them changed under warranty.
Post #139440 Tue Sep 25 2007 10:16pm
redrover
Australia 2007 Range Rover Sport TDV6 HSE Java Black
I had mine changed on the first service (6 months) for juddering and they hit me for $117 Aus for the pair Evil or Very Mad They reckon Land Rover Australia don't recognize it as a warranty issue. Sad
Post #140010 Tue Oct 02 2007 10:27am
Lateral5
Australia
Don't wear that Redrover.....it is a known defect and it is covered in a tech bulletin. Check the Global Technical Reference at http://www.landrovertechinfo.com/extlrprod...;doclang=1
MLR replaced mine FOC.
Service Bulletins are ; LTB00074, LTB000085, LR501-002 and LS501-016. Not sure which is the current one, but one of is! RRS TDV6 Bluetooth, VR, Roof
Post #140165 Wed Oct 03 2007 12:57pm
redrover
I can't get the link to work as it requires a password. The worst thing is the wipers still make a fair bit of noise as they change direction at the top of the stroke. I am really annoyed as I asked for them to check it as a warranty item and they went ahead at great expense and replace them without checking with me first. I will try and chase it up with the numbers you have given me.
thanks,
Anthony
Post #141097 Wed Oct 10 2007 3:50pm
Lateral5
Australia
redrover wrote:
I can't get the link to work as it requires a password. The worst thing is the wipers still make a fair bit of noise as they change direction at the top of the stroke.....
Yep, forgot to metion you need to sign up which is free (the only thing that is).
Mine were doing the same at top of stroke. Ask your dealer to ring Gary at MLR and he will tell him how to fix it. A new set of the proper blades(as per tech note), a shifting spanner and a small bend in the wiper arms and voila all will be fixed Thumbs Up RRS TDV6 Bluetooth, VR, Roof
Post #141225 Thu Oct 11 2007 12:52pm
