![]() | Home > Maintenance & Modifications > Oil Change |
DAVIS Member Since: 27 Dec 2005 Location: Genoa, Nevada Posts: 134 ![]() ![]() ![]() |
The primaray difference is in the additive pack. Oil that is blended for diesel engines has the ability to manage the ash content in the combustion process. The oil that is engineered for gas engines has anti foaming, viscosity extenders and other attributes necessary for its intended use. You should (need) to use the oil that is intended for your engine. While we are on the subject, oil needs to be replaced frequently if you intend to keep you vehicle for a long time. It is a myth that synthetic oil needs to be changed with less frequency. Whereas it is true that synthetic oil will hold up longer, it is subjected to the same punishment of mineral oil. The precise engine tolerances cause what is called shearing, this compresses the oil, which in turn breaks down its molecular structure. Additionally, the closed systems in today's engines contaminates the oil with the combustion by-products this will eventually cause sludge.
KenD Member Since: 27 Feb 2007 Location: Essex Posts: 34 ![]() ![]() ![]() |
Did the oil & filter change last week. Used Castrol Magnetec A1 5 - 30. Drained the oil via the dipstick hole using a P.la vac pump, dead easy and clean. The filter was also easy to change after following the oil change thread on the Disco 3 site.
