![]() | Home > Technical > Heated windscreen functionality |
| ayates Member Since: 08 Jun 2007 Location: Houston Texas Posts: 369
I had left the car outside over night the other day and in the moring the windscreen was fogged up so naturally I demisted it with the program button, this starts the fan and the heated elements front and rear. On the Rear screen I can see the hot elements clearing the screen, however the front screen didnt appear to have the same effect..... What should I see, anything ? or are the heated elements not working I wonder and its a trip across town to LR ? Brit across the Pond |
| Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146
As Josh said, it does not show like the rear one because the heating element in the front one are much closer to one another then in the rear. Range Rover Vogue ‘17 TDV6
So say given the fact that the screen is misted up outside in the morning then I turn the screen on, are you saying I should see it clearing.... if so then I think its not working ???
Yep, but it clears pretty quickly with the PROG button, especially if the screen has just got condensation on it. Even when the screen is iced up in the middle of winter, it's only 2 or 3 mins and it's clear enough to drive. |
Ayates - I find the screen pretty useless in clearing mist, it works best for deicing the windscreen. 2005 Zambezi TDV6 - Gone but not forgotten
| Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054
I usually hit the top right hand button (prog) on the console turns the lot on. After about 2 or 3mins minutes its clear as a bell and works well for misted up windscreen given that it is directing air at the screen as well as turning on the heated screen. Then I turn it off long before the prog has ran its course.
| All times are GMT |
