Home > Maintenance & Modifications > Dealer fit Privacy glass - Question from Nubie
C10CKO
Hi everyone, my first posting, so pls bare with me.
I've managed to get my LR dealer to agree to fitting privacy glass all round, foc, before I collect my 06 RRS in a few weeks.
How will I be able to tell if they have done a good job and not cut any corners? Is there anyway this could be done badly, and if so what should I look for?
Thanks,
C10CKO MY12 RRSport 3.0 SDV6 Autobiography
Orkney | Everything | Dynamic Pack | Park Heating | Cold Climate Pack | Privacy Glass | Extended Leather | 20inch alloys
Post #138653 Thu Sep 20 2007 6:55pm
Boolia
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Are you having factory fitted privacy glass or having it done at the dealers after the fact?
Post #138662 Thu Sep 20 2007 9:19pm
C10CKO
Aftermarket glass as buying a second hand 2006 HSE TDV6. MY12 RRSport 3.0 SDV6 Autobiography
Post #138665 Thu Sep 20 2007 9:23pm
PauloAmore
Scotland
Simply put, if you can see the heater elements in the rear and side rear glass, it's been fitted aftermarket, i.e. an interior film affixed to the glass.
Suppose a dealer can order panes of the factory fit glass and replace the clear stuff.
Bet he doesn't!
Search for tint or privacy in the forums for comparison shots.
FYI - Privacy is quite dark and the front windows are hardly tinted at all. Some prefer the aftermarket which gives you a bit of leeway on tinting the fronts to be almost as dark as the rear. Downside, is being able to see the heating element. I have the aftermarket and prefer less of a differential between front and rear glass. 2022 P440e AB
Post #138686 Thu Sep 20 2007 10:09pm
Josh
If I was going to use any aftermarket company then I would highly recommend Pentagon to do a professional job. Check out their web site.........there may be a dealer near you. TDV6 - gone
TDV8 - gone
Post #138701 Fri Sep 21 2007 9:05am
Jimmy_75000
Done mine with Pentagon, Thumbs Up Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #138703 Fri Sep 21 2007 9:28am
Yes, Pentagon do cracking work. BUT you won't be getting privacy GLASS from the dealer - the dealer fit option is to apply a tinting film to the existing glass, which as others have rightly pointed out.... looks a right mess. As far as fitting the film goes, I'm sure the dealer will farm it out to someone anyway and the workmanship will be fine but there's a world of difference in how the end result looks between factory fit and dealer fit. Confused
Post #138705 Fri Sep 21 2007 9:35am
C10CKO
Thank you all for your comments. The guy at the dealer I'm buying from takes Fridays off, so I can't call him today and ask. Paragon with mentioned at another dealer, who quoted me £450 for Paragon to do the job. The dealer I'm buying the RRS from has quoted me the same sort of price, or even a little more I think! so lets hope he uses Paragon.
Thanks,
Post #138719 Fri Sep 21 2007 10:57am
The dealer will almost always skim some margin out of this sort of work... if they outsource it, then it's normally going to be cheaper to engage Paragon directly to do it.
Post #138750 Fri Sep 21 2007 12:21pm
C10CKO
As he is paying, he will surely be trying to get the best deal..... for him!!
that's what worries me Sad
Cheers,
Post #138772 Fri Sep 21 2007 1:16pm
You've hit the nail on the head mate.... bad luck Wink
Post #138776 Fri Sep 21 2007 1:51pm
