Home > General > Terrain Response Dial in
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hurtling around the central coast this weekend, i had a number of opportunities to put it into Grass/Gravel/generally slippy crap mode, due to the looseness of the gravel surfaces (called roads over here). A question the book does not answer (yes i actually read it, or the pertinent bits anyway), if you are travelling at say 60-80K range in normal high range and wish to dial in slippy crap mode, do you have to put it in neutral or can you just dial it with out changing. The manual is elusive and mentions you should pro-actively set it up, where has for everything else it is specific about selecting neutral.
Jim Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #133418 Sun Aug 19 2007 7:25am
Pelyma
Just turn the dial, no speed limit as long as you aren't in off road height. You will find the throttle response different though.
Post #133421 Sun Aug 19 2007 9:23am
Zilch
Cheers, i did not notice in slippy mode that the throttle was very much more conservative Thumbs Up Another Pommie Bar Steward down under
Post #133425 Sun Aug 19 2007 9:37am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
As Pelyma has already said, just turn the dial.
You only need to select neutral when changing between high and low ratio. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #133429 Sun Aug 19 2007 10:35am
Zilch
Thumbs Up many thanks, will remember next time, it is quite easy to go from tarmac to gravel road when you are out of the Towns and in the bundooks. Another Pommie Bar Steward down under
Post #133430 Sun Aug 19 2007 10:48am
