Home > Maintenance & Modifications > 22x10" Stormer Replicas |
William Member Since: 08 Apr 2007 Location: Doha Posts: 113 |
All,
Fri Aug 03 2007 3:06pm |
They look good to me William... what's wrong with them?
Fri Aug 03 2007 3:17pm |
Shmoogle,
Fri Aug 03 2007 8:54pm |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 |
At least half a dozen members on rr.net bought these through eBay (from oemstyles4less) and have had zero issues with them up to now. If you go for them, make sure you get lug nuts that fit (they are usually not included with the rims) as the stock ones are too large. Of course, you will want to keep 5 stock lugs in the car at all times, you will need them if you ever get a flat and need to mount the spare. |
Sat Aug 04 2007 4:45am |
Hi Umberto,
Sat Aug 04 2007 9:17pm |
William, I don't know much about the Vredesteins, but both 285 and 265/35 would make a good choice for your 22s. The majority of owners here in the US seems to pick the 285/35/22s to run over those rims, since the size is still fairly close to the stock 20s (the speedo remains accurate), there are no rubbing issues and many tire manufacturers to choose from. The slightly wider stance of the 285s provides a bit of extra contact with the road, probably slightly better handling over the 265s, but mostly better looks when standing still...
Sat Aug 04 2007 10:56pm |
davidbrown Member Since: 08 Aug 2007 Location: Beside my dream Rover Posts: 11 |
Wed Aug 08 2007 9:20am |
jjb218 Member Since: 22 Jul 2006 Location: Dominican Republic Posts: 94 |
) Will they hold the weight of the car? or cause suspension problems?
Mon Aug 13 2007 10:05pm |
Hi jjb,
Mon Aug 13 2007 11:35pm |
Its a very nice tire, definitely for an SUV, after you see the 285/35/22, whats the next 3 numbers? 106,108,112? The higher the better and also thats a tire with a very good thread rating since its designed for weight!
Tue Aug 14 2007 2:15am |
