Home > Maintenance & Modifications > Removing rear lights
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
I guess its pretty much the same for the Sport as the FFRR, does anyone have a quick-tips guide to removing and replacing a rear light unit? Is it accessed from inside the car from behind the trim panel or is it a screwdriver down the side of the light job?
Ta! L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #132574 Mon Aug 13 2007 5:16pm
flydive
For the RRS.
When you open the tailgate you see 2 cross screws inboard of the tail light, you remove those then carefully pull the light aft. You might help it a bit with a plastic spatula on the outboard side(careful not to damage the paint) the first time they are quite hard to pull. '08 RRS TDV8
Post #132583 Mon Aug 13 2007 5:54pm
Josh
Reversing camera not working RRUK Question TDV6 - gone
TDV8 - gone
Post #132633 Tue Aug 14 2007 7:54am
jjb218
2006 Range Rover Sport Supercharged Zermatt Silver
Whats not working
can yo utell me more? Is this OEM?
I will help if I can amigo.
bye
JJB218
Post #132840 Tue Aug 14 2007 10:43pm
Boaz
United States 2006 Range Rover Sport 4.4 V8 HSE Bonatti Grey
flydive wrote:
For the RRS.
Good answer. Thumbs Up When I installed my rear lamp guards, this is exactly how I did it. The outboard side of the light has two plugs that pop in and out, and yes, they are quite sticky the first time you pull them out. I needed the assistance of a plastic screwdriver to help pop them out. 2006 Bonatti Grey HSE; Ebony Lux Package; Bluetooth; Sat Radio; Rails & Crossbars; Mudflaps; Nitto TerraG's; Matt. 6:33
Post #132865 Wed Aug 15 2007 12:24am
RRUK
No no! Its for my dad, he reversed his into a tree. Crunch! L319 D4 HSE
1982 Series 3 SWB
Post #133283 Fri Aug 17 2007 12:07pm
tf9
Russia 2006 Range Rover Sport Supercharged Java Black
There 2 cross screws for each light... But as said above it's very hard to remove it for the first time. 2014 Mercedes-Benz S500
2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony
2013 BMW 530d
2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Post #133433 Sun Aug 19 2007 2:45pm
