Home > Technical > ANYONE HAD THIS FAULT
Michael997
TONIGHT I WENT OUT TO MY RRS AND UNLOCKED IT A USUAL TO GET SOMETHING FROM THE CAR AND THEN RELOCKED IT, TEN MINUTES LATER I WENT BACK OUT FOR SOMETHING ELSE TO FIND THE SAT/NAV WAS STILL LIT UP WITH THE L/R LOGO AND THE RADIO LIT BUT NOT ON. I STARTED THE CAR RAN IT FOR 30 SECS AND SWITCHED OF AND SO FAR ALL NOW SEEM FINE. MY CONCERN IS HAD I NOT GONE BACK OUT THE POWER WOULD HAVE BEEN DRAINING OVER NIGHT AND MAY HAVE ALSO RESULTED IN SCREEN BURN.
ANY IDEAS, I AM STARTING TO WONDER ABOUT THE SOFTWARE UPGRADE THAT SOME OF YOU HAVE MENTIONED AS I ALSO HAVE A PROBLEM WHERE I HAVE TO SEARCH FOR A TMC STATION BEFORE I CAN USE IT AS THE SAT/NAV IS NOT STORING CLASSIC FM???????? Michael
2014 RRS diesel HSE
Post #13183 Wed Feb 15 2006 7:42pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
It has been discussed many times before, try searching on it.
Also, please switch off your caps lock! L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #13187 Wed Feb 15 2006 8:30pm
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
Yes, I've had it once...software 'glitch'...never happened since! Chips with everything
Post #13189 Wed Feb 15 2006 8:36pm
Michael997
I got very concerned re this problem too Shocked However I am to understand it does stay on for a while ( you need to time it ) but when mine went in for other issues ( new battery ) I think this was cured as it hasnt done it since. Def. get it checked out.
Post #13193 Wed Feb 15 2006 11:22pm
Geordiehillbilly
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Re: ANYONE HAD THIS FAULT
Is the TMC not storing classic a common problem? I can't get it to store or indeed search for any other station.
Post #13396 Thu Feb 16 2006 6:43pm
RRUK
Can't say I've 3ever had an issue with TMC in any car I have had it in. It just sits there and does it's stuff. Mind you, the TMC logo on the Sat Nav screen is so small it's not wonder I never look at it or notice it.. L319 D4 HSE
1982 Series 3 SWB
Post #13452 Fri Feb 17 2006 1:01pm
Michael997
Called at the dealers yesterday about the system not storing Classic FM and allowed myself to be fobbed off.
Still not working and starting to iritate as I find a working TMC as on my other car is very helpful.
I think I will have to go back and press a bit harder. Michael
2014 RRS diesel HSE
Post #13562 Fri Feb 17 2006 6:34pm
