![]() | Home > Technical > off road tires on 20?? |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
We have a couple of choices here in the US (I think Nitto also makes a Terra Grappler in a 20" size that would fit our cars, not sure if either brands are available in Europe), see threads below. However, as VA points out, your 20s are still at risk. There is only so much sidewall you can put between alloys and the ground when you run 20s...
G4LAND Member Since: 16 Jan 2007 Location: VIGO Posts: 154 ![]() ![]() |
Thanks a lot Umberto, I really appreciate this info. I know, is not the best Idea to run of road with 20”s. At the moment I have chance to have a second set of 20” wheels, so I can ply hard with one and have the second for regular use.
Yes Yuri, those are Cooper Zeon 275/45s. 285/50s would be better, but it may be a very close call on the stock rims, something somewhere may rub (I don't know if anyone has tried that size yet.) |
If I buy 19 x 8.5 wheels, which are the tires size that I can use for off road? What tire do you recommend? Yuri (ARS) XE1UN 13 RANGE ROVER SPORT HSE SDV6 Orkney Grey/Black (Spain) 07 RANGE ROVER SPORT HSE TDV8 JavaBlack/Black (SOLD) 05 DISCOVERY 3 G4 V8 (Spain) 02 DEFENDER 90 BLACK LE TD5 (SOLD) 13 FREELANDER 2 (LR2) HSE Lux SI4 Havana/Black (Mexico) |
Unless there is something new that became available very recently, the only good, true all terrain tyre available for 19" rims is still the hard-to-find Goodyear Wrangler MT/R sized 255/55R19. It is the tyre of choice of G4 fitted RRS, both because it is a terrific offroader and because, well, there ain't much else available in that size. |
