![]() | Home > General > 6 days after I bought it! |
| clutchdust Member Since: 07 Jul 2007 Location: south wales Posts: 19 |
No more than whats already been mentioned, as far as I'm aware, there's no fix for it but knocking from the front on a rr sport without ARC is caused by the front antiroll bar bushes. |
| webselect Member Since: 05 Jul 2007 Location: Devon Posts: 9
Are you the technician at Newport then? Because Cardiff didn't fix anything as far as I am aware.
Good to have more LR people on the forum - welcome Clutchdust! |
I'm the technician from cardiff, I diagnosed it and told newport what to do, power steering pump had nothing to do with it, it was the ARC pump that needed replacing due to low pressure, no further tests could be carried out till the new pump was fitted and this was the part we were waiting for for ages. After the pump was fitted, further tests were carried out and due to the pump breaking up it was found that contaminants had got into the valve block and killed it. Before I diagnosed that ARC fault, there was also an air suspension fault, the EAS ECU had gone down causing communication failure, not only with other ECU's on the car but also the diagnostic computer wouldn't talk to it, I replaced the air suspension ECU after checking the wiring to the ECU first. Sorry cardiff messed you about but thats not my fault, I just fix them, I'm just a number that does what he's told to do. |
| ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823
So after you fixed the ARC pump etc did it cure the |
Trying to be funny are you? It wasn't in for a knocking noise, it was recovered in because the red suspension light was on. |
| aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243
you f
think i need another beer |
Me upset someone |
| Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054
Hi, Sorry about Envoy. He has a habit of not reading messages properly eg. Pub selection for a meet I found your diagnosis very interesting. Have you come across this non communication ECU problem often TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
