| RRSPORT.CO.UK | ||
|  | Home > General > Aftermarket DVD stuff - problems with Alpine DVD/headphones? |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293    | jampo - I don't have the system installed but nothing less than perfect sound should be acceptable.
|  Mon Jul 09 2007 9:29am |
| jampoTT Member Since: 12 Feb 2007 Location: Hatfield Posts: 77    |
 Agree - I shouldn't be settling for 2nd best. The system is cheaper than the factory fit option, but on reading a couple of threads on here, is generally considered to be 'superior'. £1600 should have got me a DVD player mounted in the front glovebox, twin 7" headrest screens, 2 pairs of wireless dual-source headphones, and installation of everything. Checking the wiring for the black box that powers the screens on Alpine's site, it has 2 headphone sockets built in, so it should be an easy job to wire these up to a more accessible 3.5mm plug located perhaps in the plastic trim which sits between the door-side edge of the rear seat and the door itself, which would be the perfect place for cables. Or the headrest (bit messier for trailing headphone cables) or the rear of the front fridge/armrest (again, but messier for trailing cables). Additional Aux sockets for the connection of an iPod video to act as a seperate source (so 1 person can watch iPod, the other DVD, or both watch either) was going to be an extra hour or 2's labour on top, and would have been fitted to the rear of the front fridge/armrest. Wasn't done, but it WILL be... I've asked Prestige to quote me for wiring in 2 headphone sockets anyway... as its something I'd like doing, and they'll need the car back to do the Aux sockets and fix my phone cable. If they can get the wireless headphones working properly, I'll happily pay for the wired sockets. If they can't, I'll want them done for free, and a rebate of the cost of 2 sets of wireless headphones. That sounds fair enough to me... puts the onus on them to get it all to work. | ||
|  Mon Jul 09 2007 9:38am |
 Not unreasonable at all. My SC has headphone sockets in each rear door. I always figured wireless would be better though. No reason why there should be background noise on the wireless setup. I hope they are just faulty. 2022 P440e AB | ||
|  Mon Jul 09 2007 9:43am |
| jampoTT Member Since: 12 Feb 2007 Location: Hatfield Posts: 77    | Presumably good quality, well fitted wireless headphones are 'better' than wired, inasmuch as there are no wires to trail around.
|  Mon Jul 09 2007 9:47am |
| simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259      | I have an Alpine Roof monitor and wireless headphones in my D2, no problems at all that can't be traced to temp blocking of the IR receiver ports in the headphones (make sure the kids put them on the right way around!), but anything obscuring the IR transmitters would have the same effect - what model screens are they? is the IR xmitter integral or a seperate xmitter head and if seperate does it have good line of sight to the rear headrests?? Cheers
|  Mon Jul 09 2007 12:32pm |
| jampoTT Member Since: 12 Feb 2007 Location: Hatfield Posts: 77    | The screens are the compatible M780 and M780EM - each of which has an integral IR sender.
|  Mon Jul 09 2007 12:41pm |
| simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259      | Yes they sound fine - one thing that occurs is that I only have a single IR source and single source headphones, you should have each headphone switchable between the monitors, each monitor should be set to its own IR set - I don't know whether its configurable but worth checking that both monitors aren't outputting on the same IR channel and inteferring with each other. Other than that make sure no trim is obscuring the monitor front where the IR xmitter is. Final advice would be to see if it is confined to one or both monitors, one or both aux inputs to the black box etc, does it occur all the time or only when the engine and/or something else is powered up???? Cheers
|  Mon Jul 09 2007 12:49pm |
 The headphones I have are switchable source. The screens are a compatible master/slave pair, and send on different frequencies 'out of the box'. In fact setting the source incorrectly from the headphones just gives silence. The 'hiss' comes from both monitors, but they're only hooked up to one source, so I can't test multiple sources. What I have discovered is that you CANNOT alter the volume using the buttons on each screen. Or rather you can, but it makes no difference to the volume levels in the headphones. This (to me) seems like the cause of the problem. The 'hiss' sounds like the noise you get when you try and overamplify something. I reckon the output volume level from the screens is too low - evidenced by the fact that you have to turn the volume almost to MAX on the headphones themselves before you hear anything. I don't know whether the volume controls on the screen should work (or not) - but if they should, I'm guessing this is the root cause of the problem. The 'hiss' is less of an interference noise (I just went and tried) and more of the sort of noise you'd get if you had your speakers turned up really high, but your input source virtually silent. Does that make sense? Does your single screen have a working volume control built in, or do you have to alter the volume solely with the headphones? Do you have to have the headphones turned up almost to MAX? | ||
|  Mon Jul 09 2007 1:24pm |
| simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259      | Mine is the PKG-1000P, it has a built-in IR xmitter but volume is only controlled by the wheels on the headphones and no they don't need turning fully up by any means - I think your assessment is correct in that the headphones are needing to over amplify a signal that is too weak. What is the source and does the source have any setting affecting the sound output volume into the monitor black box? One option would be to take your single source's output and put that into the other aux-in on the monitor box to see if it is at all related to that aux input only. The other possibility is that the source has different outputs depending on what is is plugged into and you may be running off a pre-amp output that would then be too low.
|  Mon Jul 09 2007 1:38pm |
 Certainly sounds like the problem, if I work from the assumption that the headphones SHOULD sound OK, with no background noises or hissing! The source is an Alpine DVD player (can't recall the model number) but I couldn't find anything specific regarding input volume into the 'black box' - and to be honest, I don't know where they put the black box itself, so I'd probably need to hunt around for it... better leave it to the installers to play with - but it is all useful information in providing them with a diagnosis. To be honest, it is a shame they didn't test it themselves before giving it to me. I can't believe the sound quality is 'normal' judging from your experiences, and if it isn't, they should have spotted it and adjusted it before handing me back the keys.   Oh well, it'll get sorted out in the end. They're coming on Wed to my place of work to fit the missing Aux inputs, so I can play different things on the 2 different screens, and as the 'black box' does have connections for wired headphone outputs, I've asked them to wire those to the same place. Surely the cost to do so would be no more than the cost of a couple of lengths of cable, and a pair of 3.5mm flush mount sockets, as they've got to route other cables to that part of the car anyway... nothing ventured, nothing gained, and will give total flexibility, and the choice of using the IR or wired headphones, which would be the best result. | ||
|  Mon Jul 09 2007 1:46pm |
| NZHereIam Member Since: 26 May 2007 Location: Wellington Posts: 205      | Jampo
|  Wed Jul 11 2007 11:55am |
 Prestige collected it earlier this morning to take it back to the workshop. Whether they can hear the hiss or not, I don't know yet... I'm hoping they can (and can fix it) and isn't just me being fussy...   In fairness, Chris @ Prestige is now keen to sort this, and does agree my car probably wasn't checked over properly before being returned to me. Providing it comes back working to my satisfaction, I'll happily recommend them, as their customer service since I reported the issues (after an initial delay) has been very good, and has restored my confidence... | ||
|  Wed Jul 11 2007 12:13pm |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | Good news - please keep us posted   | ||
|  Wed Jul 11 2007 12:21pm |
| jampoTT Member Since: 12 Feb 2007 Location: Hatfield Posts: 77    | Ahhhhhhhhh
|  Thu Jul 12 2007 8:05am |
| Posting Rules
 so I'm back to being pleased again.
