![]() | Home > Technical > PDC Inactive |
RRSSS Member Since: 01 May 2007 Location: Bahrain Posts: 172 ![]() ![]() ![]() |
Hi guys,
What has probably happened is that one of the connectors to one of the 8 parking sensors has come loose. If one is not connected the whole lot fail. I had this when I fitted the winch plate and took 2 sensors off. Very simple fix. 2005 Zambezi TDV6 - Gone but not forgotten
Thanks VA, will mention it to them tomorrow and see what happens... |
Took the car down this morning and explained that it could be a loose sensor.. They checked it out and found that one of the front sensors was faulty. And, as VA correctly pointed out, if one doesn't work, all of them decide to do the same..
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
RRSSS
Thanks Kaine.. the PDC's a real lifesaver in the RRS
