Home > General > Issues with L/R dealers on warranty
Hi all
I know theres a lot in here about chips and stuff but what i need to know is if i have a chip fitted to a TDV6 are there any issues with L/R dealers on warranty?
P.S can anyone also tell me if i can fit a S/C back box and tail pipe to TDV6 with out any warranty issues? RRS TDV6 Gone but still around
Post #11869 Wed Feb 01 2006 12:26am
Pelyma
Any modification you make is okay as long as it doesn't lead to a warranty defect. If your car is chipped and the compressor goes, you would be covered. If your turbo blew and LR say the chip caused it then it would not. This extends to any extra, so for instance you put 22" rims on and it knackers the suspension you would not be covered.
Post #11882 Wed Feb 01 2006 9:23am
Thanks Pelyma do you know if i have the s/c back box fitted if it will affect the car ? RRS TDV6 Gone but still around
Post #11886 Wed Feb 01 2006 10:31am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
There's no sensible reason why swapping the back box or even better, just the tips of the exhausts should invalidate the warranty, other than the exhaust itself.
Several members have already done just that. Do a search for exhausts or tips and you shall be rewarded! L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #11887 Wed Feb 01 2006 10:45am
If you get underneath the car you will see that the exhaust is not sectional. The rear box is integral ( which includes tail pipe ) and the the pipework runs complete to the CAT.see below pic of TDv6 exhaust
What I have seen is that some members have got Exhaust companies to cut the tailpipe off and join/weld a new chrome pipe in its place.
I can also confirm that JE Engineering are looking at a replacement exhaust for the TDv6 model that resembles the S/C'd - but the chrome tip has a discreet exit directing the emitted gases towards the ground so that your car remains clean from carbon deposits.
I am having a new JE exhaust for my supercharged ( large OVALS ) - will post pics as soon as done. Very Happy
Post #11892 Wed Feb 01 2006 11:39am
ON EBAY 1/2/2006
As from pic above I now see the firm in Nuneaton ( my home town ) are also selling a S/C exhaust system which they say you can fit on a TDV6
http://cgi.ebay.co.uk/Range-Rover-Sport-Su...dZViewItem
Post #11894 Wed Feb 01 2006 12:17pm
Pelyma
Who knows, depends how much is at stake I guess and how good your knowledge is at proving the failure was not down to the modification. Could a non standard exhaust system put heat in the wrong place and affect the wiring, I don't know but that could be an avenue Ford take!
Post #11899 Wed Feb 01 2006 1:36pm
RRUK
When you look at those two pics, you can see there is no difference in exhausts between the TDV6 and the V8 SC, other than the SC comes in Stainless Steel.
Surely a force fed 4.2V8 petrol should have a different system to a Turbo charged diesel that's only 2.7ltrs?
Are the main pipes of different diameters does anyone know? L319 D4 HSE
1982 Series 3 SWB
Post #11914 Wed Feb 01 2006 4:21pm
Aren't the differences going to be at the manifold end? Er.. I'm no mechanic so if that's a stupid thing to say, I apologise! Laughing
Post #11917 Wed Feb 01 2006 4:37pm
Just been talking to a friend that worked on the L/R production line. He told me that the only difference he could see was the tips and he thinks there are the same size on the S/C and TDV6 so it should just fit on with a spot of welding
Thats all fair and well but by doing this anyone know if it will affect the working of the engine? at the end of the day it may look good but i don't want to lose my warranty by doing this. (confused don't know what to do) RRS TDV6 Gone but still around
Post #11931 Wed Feb 01 2006 5:04pm
JayMann,
why not try giving http://www.jeengineering.co.uk/ a call. Ask him what he thinks.knows about the standard fit exhausts etc .... just a thought, also they have done mods on exhausts for the RRS both TD and S/C & may poss have the standard s/c ones to p/x if you dont want to go for something different?
I dont think it will effect your warranty at all.
Post #11934 Wed Feb 01 2006 5:13pm
HI all thank you all for your help it was a big help but i don't think it will work i may just have to buy a set of overfinch tail pipes RRS TDV6 Gone but still around
Post #11986 Thu Feb 02 2006 11:16am
Josh
Hi, Can anyone tell me why the Tdv6 has got stumpy downwards facing non aluminium pipes? and what effects the carbon might have on a straight S/S exhaust system?
Thanks. TDV6 - gone
TDV8 - gone
Post #11997 Thu Feb 02 2006 12:07pm
You'll find most modern diesels have pipes that point down towards the ground - the idea is that the carbon deposits in diesel exhaust don't get thrown out into the air. It'd also make a bit of a mess of the back of your car too...
Post #11999 Thu Feb 02 2006 12:11pm
Josh
Hi Shmoogle,
This is my first venture into the world of diesel. So not a good idea to have straight pipes with a silver RRS then unless I want to wash it every couple of days. Rolling Eyes
Thanks. TDV6 - gone
TDV8 - gone
Post #12007 Thu Feb 02 2006 12:23pm
