![]() | Home > General > Pothole Problems |
When you say shut down did the RRS simply stop or did loads of warning lights come on? If it's the later a simple restart of the car as your friend did often cures any problem, this will be the same od the D3. 2005 Zambezi TDV6 - Gone but not forgotten
At least it didn't wreck half of the wheels on your car like it did to mine recently.... |
peteau Member Since: 20 Jun 2007 Location: AUSTRALIA Posts: 3 ![]() |
Hi My apologies for the delay in replying. Apparently, in each case, 'loads' of lights did come on. They went off one by one and then a restart fixed the problem. I guess from this, that there must be some sort of sensing system within the suspension that measures dangerous excursions of the components. Is this the case please? I have a Disco 2003 TD5 and a manual reset of a switch on the firewall is needed if a severe shock triggers a total shutdown. Thanks for your interest. Pete |
Gawd! That sounds as though there is an interesting story there around this. Pete ![]() |
ivery819 Member Since: 16 Jan 2007 Location: -- Posts: 1241 ![]() |
Yeh!
Thought I'd posted about this....
That's a BIMMER BUMMER |
