![]() | Home > Technical > Engine Fault Light On |
Should Know Better Member Since: 04 Jun 2007 Location: Essex Posts: 20 ![]() ![]() ![]() |
Hi - Apart from the obvious answer "take it to a dealer" which I am shortly about to do - is there any way to reset the light on a RRS S/C - or at read the "diagnostic trouble code" ?
Take it to a dealer |
Mmm.... Why didn't I think of that .... ![]() |
Thanks for that - I had read the manual hence not "too" concerned about the cause, the light doesn't flash and there is no loss of power and the vehicle doesn't go into "limp home mode". I'm pretty sure there isn't an "i" but I'll go and and have another look to make sure!
The dealer may have taken it so quickly in case it is safety related.......................... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Actually a mate of mine's Golf has been reporting engine mgt troubles and the dealer won't actually give it back until it's sorted... seems they view the problem as dangerous. |
Mmm - I'll let you know what they say |
All done, the culprit being a Lambda sensor apparently. |
Glad to hear you car is now sensing all it's lambdas |
Maybe it was making the engine run too rich and therefore explains the 14mpg I've been getting? |
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
Thats right S they were
