![]() | Home > Technical > Blinker Relay... Help please! |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
Did you try the fusebox in the engine compartment? Malaysia Boleh!
| PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546
I suspect there isn't an actual relay. The sound you hear when using the "blinkers" isn't a relay, it's a digital sound.
| antics22 Member Since: 29 Sep 2005 Location: Alhambra, CA Posts: 39
Well, looked under the hood (bonnet for you uk folks!) and looked at the fuse box, no signs of a relay for the blinkers... there were plenty of relays there for other things, but no blinkers.... any other ideas? PaulB, the sound IS coming from the dash, but there has to be a relay to make the blinkers work.. .right??? PS. to recap, I have checked behind the glovebox, under the bonnet, and under the steering wheel... Any help is appreciated! |
| Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662
I think the indicators are probably driven by a body control ECU instead of a flasher relay - GTR will tell you for sure |
As suspected, it's electronically controlled internally to the Central Junction Box. The indicator switch and hazard switch only provide switched earth signals to it |
As I said, its all digital. The sound you hear, which would normally be the relay switching, is actually a digitised "impersonation" of the relay.
| vesurover Member Since: 31 Jan 2006 Location: USA Posts: 4
Antic did you put in led turn signals? |
Thanks for the information guys.... Yes Vesurover, I started experimenting with LED's and wanted to replace the relay with a heavy duty electronic one... but looks like I am out of luck and have to go with the resistor(s) alternative instead.... will update with pics when I am finished with my lights. |
Martin, thanks for looking up the blinkers on the GTR site...
| tasmod Member Since: 07 Aug 2005 Location: NE Lincs Posts: 396
Thanks Tasmod, I will check there tomorrow morning! Its 1am here in the US and I have lost ALL track of time trying to research this online... Will update with my findings. |
| MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598
Hi antics22,
