| RRSPORT.CO.UK | ||
|  | Home > Technical > Phone problem |
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944      | The multiple connections feature (often referred to as Call Waiting in the US) is only supported with cradled phones, not when using Bluetooth. The manual may not specifically say so, but that's the way it is, whether your phone is on the LR approved Bluetooth list or not. Attempting to answer a 2nd incoming call with the steering wheel "Answer" paddle does not work, and even using the handset keypad to switch between calls often causes the LCD in the car to freeze - with one or two calls shown as active - even after you hang up. Both End Call paddle on steering wheel and End key on handset do nothing and the radio stays muted, as if you are still on the phone.
|  Tue Jan 24 2006 11:35pm |
| Posting Rules
